Bonnet to nose pin and grommet
I had four latches on the last car, worked fine and they're one of those things you get so used to seeing they sort of disappear after a while.
You can catches in black too, which on certain car colours makes them even more discrete.
Otherwise you're into fitting a Dzus catch type arrangement.
Might not be a bad idea to go with 4 black catches (had not seen them in black). Bodywork is black so should be fairly discrete.
Thanks!
