Brake Master Cylinder Pre-Lit
Think it's off a Mk3 Cortina or Mk2 Escort. Casting number   646776860305G. equates to Lucas Nos PMD 282 or PMD 225.
I already have the barrel but really need the reservoir. It has the number 74470131 on it and Girling LH4 on the bottom.
The distance between the hole centres on the cylinder is four and a half inches. 19mm bore.
If not does anyone know of another cylinder that will fit without major mods.
Cheers,
Jim.   :p
  • 2 weeks later...
If the item you are looking for is the same as my '88 SEi, I have a master cyl and reservoir but the seal leaks onto your boots from the push rod. Any help?
steve@kilbey.fsnet.co.uk
