Odyssey pc680 battery fitment
I currently have a halfords battery in my Westfield, it's a small one, all I could get to fit in the battery tray at the time, but it struggles to start my 2.0 Zetec, especially from cold
I've done a search about & it looks like the Odyssey pc680 battery is a popular choice, my question is does it fit on the stock westfield battery tray ? Or do I need to change the battery tray, I'm also looking to use the over bracket that can be bought with the battery, also I will need to change the terminals
Any pictures of the battery in place would be greatly apreciated
Thanks in advance
the battery over bracket makes a neat job of fitting the PC680
You can just screw in some M6 bolts and the cut head and thread to required stud + ve and - ve length needed. Just needs nuts and washer to fix cables
It fits fine, have that on mine.  You'll have to take off the old battery tray and fit some rivnuts to hold the new clamp. Also the battery terminals need to be changed to the eyelet type, the terminal screws are very small, 5 mmm. I think.
sorry ---check M5 or M6 threads to battery
Got one of those BCF
Starts my zetec no problem
Doesnt like being left for weeks though
These look good value - might get one as a backup at that price
I'd be concerned that a relatively standard car battery won't start the engine.  It could be a duff starter or battery.
I found an Odyssey battery that fits the standard tray lying down.  Although its half the capacity, as the motor usually starts within 3 pulls, that's enough.
