Sinbad Posted February 25, 2015 Posted February 25, 2015 Trying to fix a problem with some trim on a Focus. The crome strip on the bonnet is somewhat springy and need to find the best adhesive to hold it in place. Have tried "normal" mastic but without success. Suggestions please as to what would do the trip. Cheers Paul Quote
Geoffrey Carter (Buttercup) Posted February 25, 2015 Posted February 25, 2015 Morning. Does that 3M tape work. Quote
Rory's Dad Posted February 25, 2015 Posted February 25, 2015 ...or my favourite - Gorilla glue! Quote
SootySport Posted February 25, 2015 Posted February 25, 2015 You can buy special external trim tape for this sort of thing. Place's that sell autopaints and sundries sell it. If it's just a couple inches required, Number plate tape works just as well. Quote
Sinbad Posted February 26, 2015 Author Posted February 26, 2015 Picked up some number plate tape from my local motor factors today and will attempt the fix tomorrow in the dry. Thanks for all the pointers! Quote
clive_r Posted February 27, 2015 Posted February 27, 2015 I've used Halfords trim tape on body mouldings very successfully, although admittedly there was no 'spring action' to overcome. Quote
clive_r Posted February 27, 2015 Posted February 27, 2015 Also, if you're using tape this time of year heat the areas to be fixed with a hair dryer, gives a much better bond. Quote
