Crossflow Oil filter
Am slightly confused about the seemingly wild array of part numbers and alternatives, so maybe someone is able to help.  Want to do an oil service before I take the car back on the road and took note of the part currently on there: FRAM PH966B.
I then compared it to Burton's advice, and they reckon a EFL500 is the jobbie for a Crossflow.  However, if I look at http://www.oilfilter-crossreference.com/convert/Fram/PH966B, then the EFL500 doesn't feature at all, so I am going to assume they are not the same at all?  Should I just play it safe and get another FRAM PH966B (£9.99 on Amazon/Ebay, but it looks nothing like my one), or should I be buying something else?
The reason I'm hesitant, is that I'm reading many negative reviews on the FRAM...
I was recommended a Mann W712/43 by my local motor factor.
Not sure what the differences are between filters to be honest...
Spend £5 on new filter ,change each year 3k miles not a problem.
Honestly don't think it matters.
Fram are OK, can't be much of technical reason why not.     I buy a few at a time from my local car parts shop to get a discount.
Well, comparing this part number with the equivalent of FRAM, and then comparing the two FRAM options, the difference seems to be that yours has an anti-drain valve and a pressure relief valve, and mine doesn't.  Having done a bit more googling, it seems these two options make good sense to have, so I'll probably go for one of those as well  :yes:
Edited: compare http://www.framcatalog.com/PartDetail.aspx?b=F&pn=PH3614 to http://www.framcatalog.com/PartDetail.aspx?b=F&pn=PH966B
Cool, glad it was a useful post..!
And when you say "pressure relief valve", every XFlow already has one, it's called an oil leak...
LOL!  That is very true...  Trying slowly to eradicate them though ;)
I used a MAHLE filter (possibly the OC23), they we're so cheap (about £3-£4) that I bought two, back when I was buying oil and some other bits online from Opie.
Could you verify the part number for me please?  I still haven't ordered anything, so the more options, the better.
There are two for the x-flow, the OC21 for the 1.3 and the OC23 for the 1.6, and IIRC the only difference is the OC21 is shorter, so I have a feeling I bought that one in order to avoid having an oil filter sticking out below the chassis rail.
But I shall take a look when I get back home later!
What i'd defo avoid is the Halfords own brand filters, i've heard very bad things.
Happy to be corrected, but as I understand it if the flow rate/pressure is too great to pass through the filter it will result in the oil flowing via the by pass valve and not being filtered. I presume the larger filter has more surface and can therefore filter a higher rate of oil.
Always ran a standard Ford Motorcraft filter on our old crossflow once pipercross stopped selling them. After 11 years of abuse it was stripped with no reported wear - unfortunately it have two burnt out forged pistons and scrapped, but that's another story  :cry:
Confirmed im running the MAHLE OC21.
Regarding size versus flow, the filter will have been designed taking into account sludge buildup and I change the oil so often that'll never happen.
According to MAHLE's spec sheets: http://cdn.opieoils.co.uk/pdfs/mahle/mahle-filters-uk-catalogue-2014.pdf    (Page 122)
OC21, all Escort (1.3 up to RS1600), except the RS2000
OC23, all Cortina except the 1.3
Thanks for that  :yes:
