What to buy to tidy this up
Struggling to find the name of a part to put around the steering column to tidy this mess up. Trimmed vinyl aint my thing... Any suggestions as to what to search for?
173296CE-B3A3-4728-8B52-D50AFA7BE39F_zps
A larger rubber grommet
Maybe ?
Bud should you be taking pictures at 5mph ?
Like Martin said pipe collar.
You could try and find a 'Top Hat' bush or Flange bush.
That should sort it neatly provided you can a suitable size.
What size is the dash hole ID and column OD?
A piece of plastic or alloy tube either covered to match dash or painted matte black?
You could slice it along its length to go over column if your dash is hard to remove,if your dash is easy to remove fix the tube from the rear of dash and slide over column?
what about a cv boot
wide part attached to the steering wheel boss and the thin end sat on the column
Escutcheon! (Lovely word, that...) :)
