TableLeg Posted February 15, 2015 Posted February 15, 2015 What is the norm with regards to P clips for securing the Metal Brake and Fuel pipe? I already have plastic P clips that fit the Brake pipes I can use. What about the fuel line? I would have thought rubber lined Metal clips would be better. Any comments? Thanks in advance. Quote
Mooch Posted February 15, 2015 Posted February 15, 2015 I used plastic P clips for brake and fuel lines with no problems - fine for IVA and no probs in use since. I used metal/rubber clips for larger diameter hoses where needed. Quote
TableLeg Posted February 15, 2015 Author Posted February 15, 2015 I used plastic P clips for brake and fuel lines with no problems - fine for IVA and no probs in use since. I used metal/rubber clips for larger diameter hoses where needed. Thanks Mooch, I'll have a look at some Plastic P clips for the fuel line then. Quote
Valentinik Posted February 15, 2015 Posted February 15, 2015 I hope the OP doesn't mind me going slightly off topic, roughly how many P clips should i need for the brake and fuel pipes? I wasn't sure if these are included in the kit so was planning on buying some before mine is collected Thanks Mike Quote
TableLeg Posted February 15, 2015 Author Posted February 15, 2015 Well you should probably be looking at a clip every 8" so based on your desired routing you should be then able to work out roughly how many you'd need. Hope that helps. 1 Quote
Valentinik Posted February 15, 2015 Posted February 15, 2015 Well you should probably be looking at a clip every 8" so based on your desired routing you should be then able to work out roughly how many you'd need. Hope that helps. Great thank you Quote
