Handbrake handle
Dumb question but how do/did you get that "handle" part off? I tried mine recently and could not see how it is fixed/secured.
Grab it, and then whilst trying to rotate it, pull it at the same time.  Should just come off, but may be a bit stiff in the beginning to break the 'bond'.  Unless someone glued it on, then you will probably never get it off...
Yep the old sierra ones just pull off, not sure on the the new ka ones or if you can change them yet!
Like that one too, cheers!
With the matching gearknob I think it will look good once the tunnel is covered and I've got a handbrake gaitor fitted :)
