Steering Wheel
Does anyone have a 70/75 PCD wheel? Ideally drilled for 6x70/75 PCD.
I need a new steerig wheel - but as Im on the standard 300mm wheel with the old boss Im going to buy the more widely accepted boss (when supplier gets stock) ideally after 270-300mm diameter for the new wheel and flat bottom is good/fine.
It's a 70/74 PCD you need.
I knew it was around that. WiFi is slow so didnt google to check.
  • 1 month later...
Anyone? Ideally pre-drilled. Will be looking to buy new very soon otherwise.
