Store Testing In Progress ×
Fuel tank for narrow body (fuel injected)
evobat
Hi,
I am after a fuel tank for a narrow body sei for a fuel injected setup. If there are none about, does anyone know where i can get one made at a resonable price in essex?.
Link to comment
Alloy Racing Fabrications (Not in Essex) produce a fuel tank for narrow bodied cars and can also manufacturer or modify to your requirements.
http://www.alloyracingfabrications.com/fuel-tanks/westfield.html
In Essex I've used both MJS Fabrications and most recently John Danby Racing for my fabricated parts
http://www.mjsfabrication.co.uk/
http://www.johndanbyracing.com/
Link to comment
As an alternative, FBB just drilled a hole in the top front to bolt in a return pipe, gaining access via the fuel sender. Then just use the existing low pressure pump to feed a hp pump etc etc.
Good luck.
Link to comment
Hi Pete,
I had the original tank modified for the return pipe etc and all worked ok. The tank seems to have started sweating fuel or has a slight pin hole. I would get it repaired but when i bought the car the previous owner had moved the fuel pick up pipe to the bottom of the tank and also looks like a bit of a mess and makes the pipe quite low to the ground.
Link to comment
