westfield sei narrow rear hubs
Stripping my Westfield at moment and got to rear hubs.... not sure what they are from, was looking to replace bearings and discs whilst its in bits. Anyone know if they were from production car?
Few details
Sei narrow
Rear west ally uprights
Looks like sierra rear calipers
Thanks matt
they are westfield items .you can get bearings. I think they are Volvo ones. once you push them out you should be able to get the part number. beware they sometimes not easy to remove. you may need a big press. soak well with release oil
Volvo 440 bearings rings a feint bell.
Yes, here's a handy thread and another. Some part numbers etc in those threads, but essentially Volvo 440 front wheel bearings.
Note, that's if you've got the Sierra rear diff, if you have the Escort one in the Westfield casting, I'm not sure if they're the same or not.
Yep escort diff with Westfield back casing. I'll try to get  bearings  out see if part numbers visible.
Think the rear discs are  - fronts from escort mk3/mk 4.....?
I think the bearings are std  whether  sierra or English diff.
Bearings are all the same.
I look forward to seeing this mighty cross flow in the speed series next year. Good luck oh Mighty brother with the 8V power plant... :yes:  :d
I'm not surprised, but thought I'd better mention it in case!
the mighty xflow has gone I'm afraid................
Quite sad really, but the rest of the car needs alot of attention. So, stripping back to bare and starting again.
 more likely be 2016 for speed series. Possibly do thoresby at end year as I live just down road.
