Nick Algar - Competition Secretary Posted December 16, 2014 Posted December 16, 2014 Just taken out of a Force racing car, complete engine with SBD Dry sump system, SBD Clutch actuator. Holeshot turbo set up specification as below, was stripped at the beginning of the year and gearbox fully rebuilt, the engine was checked over, but all in good condition. Has only done 4 sprint events since. Turbo Kit Parts Modified GT30-71 RS turbo and wastegate, Headers, aluminium airbox plenum with Holeshot, cnc machined injector mounts and fuel rail, Tial Blow off Valve & Wastegate. Oil feed line and fittings to turbo, oil return line and fittings from turbo, vacuum and fuel hoses and fittings, ITG Air filter, uprated injectors 750cc, Holeshot Injector rail, injector connectors and spacers, Turbosmart billet fuel regulator and fittings. Engine Kit Parts Turbo pistons, cyl’ barrel spacer, Adjustable cam sprockets, Heavy duty 10mm cylinder studs and nuts, clutch spring kit with spacers and bolts, Carrillo Conrods Turbosmart boost valve. What you see in the pictures is what you get. Sorry but not able to see it running. Also see my advert for MBE ECU & Wiring if interested. This has the map for this engine in it. £ 7,000 would cost a lot more than this to build. If interested PM me or call 07770 nine 3467 three or email nick at plays-kool.co.uk
Young Pretender Posted December 18, 2014 Posted December 18, 2014 If this came with a car westfield wrapped around it I would be keen glwts
Nick Algar - Competition Secretary Posted December 18, 2014 Author Posted December 18, 2014 If this came with a car westfield wrapped around it I would be keen glwts Anything is possible but you would be talking big bucks If it doesn't sell then that's probably what I am going to do with it
