D7PNY Posted December 12, 2014 Posted December 12, 2014 Agreed Dave. I've now realised that I have no idea what the wiring is so have to figure it out without the assistance of the factory. Cheers, Dave Quote
Barry Ashcroft Posted December 12, 2014 Posted December 12, 2014 Much nicer mounting bracket then my dominators and the huge hole really annoys me, might have to get some of these Quote
John Williams (Panda) - Joint Manchester AO Posted December 13, 2014 Posted December 13, 2014 Agreed Dave. I've now realised that I have no idea what the wiring is so have to figure it out without the assistance of the factory. Cheers, Dave I'll go through mine today and let you know what it is. Quote
Steve M Posted December 13, 2014 Author Posted December 13, 2014 Thanks for all the comments Just ordered a pair from Westfield, patience was needed though as the site kept re routing !! Definitely worth ringing direct though, website stated no stock, but they are in stock !? Used the 15% off voucher too. Quote
Steve M Posted December 16, 2014 Author Posted December 16, 2014 I'll go through mine today and let you know what it is. Mine arrived today John, did you have a look at your wiring for us ? Quote
SootySport Posted December 16, 2014 Posted December 16, 2014 Much nicer mounting bracket then my dominators and the huge hole really annoys me, might have to get some of these Just buy some large blank grommets and drill your own size hole through them. 1 Quote
Andy (Sycho) Posted December 16, 2014 Posted December 16, 2014 They are a bit of a pain to wire to get them to work is easy, but to get the main beam warning light to work correctly is a different mater. It doesn't help that you have five wires but only three colours. You have to join the two earths together which is black on the main bulb but white on the side light which is a bit odd you would think they would be the same colour. 1 Quote
Stu Faulkner Posted December 17, 2014 Posted December 17, 2014 IIRC (I can double check) You will have to open them up and the main lamp is- Yellow = Low White = High Black/White stripe = Earth The side light is- Yellow = Side light White = Earth. I connected the two earths together in the lamp so you only have four wires. Quote
