Crossflow sensors
Just need a quick confirmation that I've got these two right?
Images shamelessly stolen from Westfield World so apologies if they are yours ;)
Are there any other sensors that I've not found yet?
First one is the temp gauge sender, second looks like the rad fan temp switch.
There should be an.oil pressure sender at the front right of the engine, right down at the bottom.
Hmm, so the 1st one connects to the water temperature gauge, and the 2nd controls the engine fan? Good thing I asked!
I'll have to look for the oil pressure sender...
Oil pressure sender is on drivers side, front, about halfway up the block.
Quinten,  just hold the steering wheel and feel the soul of the engine... do away with this modern trickery my friend  :d
Turn key, drive the mighty one, don't need any gauges there bullet proof..
So, the location varies then ;)
I would, once I get the wiring back together again! :d
It's here
Depending on your set up, you may have another one in-line as well, but that is the main sender.
Sorry, meant right when you sitting in the car - as per bcf - drivers side.
Cheers Barny and Pete! No guesswork involved then this time. Think I've got my wiring loom 95% figured out, so getting there... am enjoying this more than the exhaust manifold shenanigans ;)
