Barry S Posted October 30, 2014 Posted October 30, 2014 Hi Everything you need to make a standard 2.0L 16v Vauxhall XE redtop produce 184.3 BHP (2 separate RR graphs available) along with a good spread of useable torque. I used this set up for fast road and competition use until I went to throttle bodies and could not fault the drivability or power delivery. Twin 45 DCOE carbs complete with K+N filters, matched trumpets, inlet manifold and underslung linkage to suit 2.0L 16v Vauxhall XE red top engine. Bosch distributor, coil pack, ignition module, heat sink and HT leads Early SBD exhaust manifold, mild steel, do not confuse with Westfield exhaust manifolds, this has much larger primary and secondary pipes and the exit has an OD of 2 3/4 inch. Easy bolt on reliable power £500.00 the for all of the above, pics below Cheers Barry
tolf Posted November 25, 2014 Posted November 25, 2014 Barry Will you sell the carbs seperately? Thanks Ian
