Leaking Heater
Hi,
    anybody know where I can get a heater matrix,part no.RH2155.Westfield factory only supply the full heater,at expensive money.
                                                          BJK
Take it into a radiator re-manufacturer. they can recore it for you.
It's a (classic) Mini heater matrix, usually plenty on eBay and the Mini specialists.
You can also get an all metal one that's very good, though it doesn't fit the Westfield housing quite so well, it does work though
Thanks SS,will check out local sources.
Thanks Dave,another outlet for me to investigate.Your kindness prevents me from uploading the pix I took of you at Ty Croes!
:rolleyes:  :oops:  Now I'm worried....
Get rid of it, Man up..., who needs heaters in open top cars,
Good Gilet, beanie and a snood... Come on lizard..
thinkturbo,never had it on,just that the bl**** thing is leaking all over the passenger side footwell!
Dave,just pix of what a good AO should be doing!
