Boombang Posted October 11, 2014 Posted October 11, 2014 Rather than forking out for a new one, wanted to see if anyone had a used one? I don't mind borrowing if someone would rather lend that sell.
pete g Posted October 11, 2014 Posted October 11, 2014 you can borrow mine if you want to come over and collect
blue ass fly Posted October 11, 2014 Posted October 11, 2014 I want one too Cheapest ive seen is ebay for £30 Hopefully santa will bring me one
ALLADDIN Posted October 12, 2014 Posted October 12, 2014 I forked out a while back , from fast road cars outlet on ebay. Very glad I did , makes life so much easier
Boombang Posted October 12, 2014 Author Posted October 12, 2014 Am thinking for the sake of £40 I'll have one forever then.
Boombang Posted October 12, 2014 Author Posted October 12, 2014 Just ordered one, be interesting to see what make it is when turns up.
Terry Everall Posted October 12, 2014 Posted October 12, 2014 If you have large dia trumpets you may need to use a plastic funnel to reduce dia etc
Boombang Posted October 19, 2014 Author Posted October 19, 2014 Bought from JJC on eBay and a pucker German made STE job turned up. 30 seconds later got it balanced, 5 minutes later it's idling like a dream all the way down to a solid 900rpm. Within 10 minutes I've identified the pump jets are a touch large, swapped them out and got it as good as I can with the jets I have. Want to try a slightly smaller idle or leaner idle holder, with a slightly smaller pump jet, but it's certainly close enough to hand over to the professionals and get on the rollers.
Lawrie Posted October 20, 2014 Posted October 20, 2014 Money well spent. :-) Yes, but its proved that there are differences between the chokes in each carburettor. Has anyone got a solution to that? The bible doesn't seem to cover it
ALLADDIN Posted October 20, 2014 Posted October 20, 2014 Either leaking or twisted spindle ? Is it a significant amount ? Or leaks in manifold etc of course.
Man On The Clapham Omnibus Posted October 20, 2014 Posted October 20, 2014 I use this instrument http://www.dellorto.co.uk/merchandise/products_details.asp?PartNo=MANOMETER4&CategoryID=2&PartsectionID=59 bought from Eurocarb in Reading. If you have the vacuum take-offs it's quicker than measuring individual venturis one at a time.
Lawrie Posted October 20, 2014 Posted October 20, 2014 That's posh. Eurocarb do have some good kit Either leaking or twisted spindle ? Is it a significant amount ?Or leaks in manifold etc of course. I think its been the same from new. Meter reads 5 on one choke and 7 on the other. Both butterflies are slightly open
ALLADDIN Posted October 20, 2014 Posted October 20, 2014 I do have a similar mercury set but webers don't always have takeoffs . 5 and 7 seems a fair bit: have you checked the both butterflies sit fully closed when they are supposed to be.?
