1997 Westfield Wide Body SEI-easy project-SOLD
CAR NOW SOLD.
Being sold as a small project-either as a rolling chassis or supplied with a brand new and unused Ford 1.8 black top Zetec.
Built from all new parts (receipts included) excluding engine, gearbox and differential and registered on a `Q` plate in April 1997. To date the vehicle has covered only 13021 miles with previous MOT certificates to validate. The car is in very good condition and could be completed in time use next year, only selling as I have been reunited with my original 23 year old Westy which requires restoration!
Specification
Front suspension-wishbones chromed.
Brakes-Front Cosworth 4 pot calipers & G&D ventilated discs mounted onto Westfield alloy uprights.
Brakes-Rear Cosworth 2 pot calipers & G&D discs mounted onto Westfield alloy uprights.
Cosworth LSD
TSW Blade wheels - 7.5” wide x 16” diameter, fitted with Yokohama AVS 205 x 45 tyres.
Interior – ZEI contoured dash and VDO instruments.
Momo steering wheel and quick release boss.
Corbeau sportsman seats & head restraints.
Willians 4 point harnesses.
Westfield carpet set and leather gaitors.
Body-Oxford blue with yellow front & rear wings and nose cone.
Locking boot lid
Westfield chrome rollbar
Floor mounted pedal box.
Full weather equipment including contoured side screens.
Epoxy coated chassis
Facet fuel pump
Reconditioned MT75 5-speed gearbox with quick shift selector.
VW polo radiator
Westfield stainless steel silencer and cover.
As mentioned previously, available with or without brand new & unused Ford Zetec Blacktop engine 1800cc.
Car without engine £4500
Car supplied with new engine £5000
Parts required (depending on engine selection and specification);
Engine mounts and rubbers
Coolant hoses & clips
Starter motor
Alternator
Exhaust manifold
Clutch
Engine management or carbs
Contact details
Telephone Dean in Bristol : 01454 886602
Email : Annette.dean@blueyonder.co.uk
Images
http://i32.photobucket.com/albums/d37/picky1/DSCN0906_zps689315fc.jpg
Hi i am a newbie looking to purchase my first westfield in the near future. You mention your stunning example comes with the 1.8 Zetec, i was just wondering how much work would be involved to install it ready to run. I would say im fairly handy with basic mechanics so not too concerned on that point. Just wondered how involved it would be. Does the engine need a baffled/shortened sump fitted? If i were to go for carbs does this do away with any engine management system? Any extra comments/advise would be greatly received. Thanks,
You'll need a sump for sure. Carbs will still need an ECU, albeit a cheaper one than that required for Injection. But (from my own research as I am putting a Zetec into my car) here's a list of sorts:
Sump
Flywheel
Clutch
Starter Motor
Clutch Cable
Clutch Arm
Release Bearing
Throttle Bodies/Carbs
Manifold for TBs/Carbs
Air Filter
Engine loom
ECU
Engine Mount Arms
Engine Mount Rubbers
Small Alternator
Spigot Bearing
Hoses
Belts & Pulleys
Exhaust Manifold
It all adds up.
Looks like a tidy rolling chassis though - and it is IVA'd so that's a bonus.
Thanks for the advice. Lots to think about.
Don't be put off - all part of the fun :)
Don't forget this is a great club with lots of plentiful advice and second hand parts at competitive prices, I have seen shortened sumps for sale on Ebay for a little over £100. I believe this car could be completed for little outlay especially if you are not in a rush to complete.
  • 2 weeks later...
Car is now sold, thanks for the interest.
Thanks Dean over the moon with the new purchase. Probably just go and stare at it for a while in a bit. Again!
Might be worth a look on locostbuilders.co.uk search for posts by big_wasa if you fancy using the std injection as he knows how to get it running with std ford ecu (cheap as chips)
