2001 Westfield Megabusa Turbo Race Car
Road Registered but Race Ready (Needs nothing to compete.)
I’ve been racing my beloved Westy for 7 years with SEMSEC and of late BARC in the Sevenesque series, due to work commitments I have decided to part with her (Not an easy decision)
I did 3 seasons with her in normally aspirated trim and managed to win the SEMSEC Overall Club Championship in 2010, with 11 wins and 3 seconds out of 14 races, best lap on treaded tyres round Brands Hatch was a respectable 52.3 seconds with 165hp at the tyres. I then decided to up my game and turbo charged her.  Initially I had gearbox problems after I fitted a Quaife gear set, but after ditching that and using an Extreme Engines modified Suzuki set, she’s been as good as gold.
I have dyno printouts for 310hp at 10psi of boost, she is happy at about 1 bar though, which should equate to around 350hp. The engine is built to the same spec as the motorcycle drag racing boys with 600hp.
Of late she’s done the Birkett, with a lap of 2.19 round the Silverstone GP Circuit and had a second and a win at Rockingham in May, then Brands Hatch in July she had 3 thirds, best lap 51.3 seconds. The best lap I’ve had round Brands on (old) slicks was a 50.5, I know the car is capable of a sub fifty lap and I’m devastated not to have achieved it!
With 350hp and around 530kg’s this is a blisteringly fast car, footage of her in action can be seen on Youtube under Steve Garner
In the time I have raced the Westfield she has never been in any kind of impact or crash, she has however picked up the usual battle scars and chips associated with racing, I have decided to tidy the car up but will not be spraying or re-bodying her, this is reflected in the price  I am hoping for.
I am prepared to arrange a trackday at Brands Hatch for genuine parties that can prove some sort of previous experience. I am also prepared to give support to the new owner (for a sum to cover my expenses) to get them going.
Chassis.
Megabusa Chassis (Registered 2001)
Caged Full Race Cage
Widetrack Front Wishbones
Nitron Suspension
Front and Rear ARB’s
Westfield 4 Pot Race Calipers and Vented Discs, Sierra rear Calipers
AP Racing Master Cylinder
3.1 Sierra LSD (Built by Road and Track about 15 Hrs ago)
Radtec Radiator with Swirlpot setup
Fuel Swirlpot (Low and High Pressure fuel pumps)
Extra Wide Rear Arches
Bailey Morris 2 Piece Propshaft (No Reverse, but turns round in her own length!)
Tillet Race Seat
TRS 6 Point Harness (Purchased April 2014)
Plumbed in Fire Extinguisher (Serviced April 2014)
Momo Suede Steering Wheel
Compomotive CRX Rims 7” Front 8” Rear (Plus 10” Compomotives for Slicks and various rims and Tyres included)
Shod with Avon ZZR’s (Done about 3 Hrs)
Odyssey Race Battery
Transponder
Engine Specification.
Dyno sheet showing 310hp at just 10psi boost, 350hp in race trim.
Engine rebuilt including Mains, Big Ends, Piston Rings and Nicosil Replate less than 7 Hours ago
Bob Farnham Gas flowed Big Valve Cylinder Head (Rebuilt less than 7 hrs ago)
APE Turbo Spec Valve Springs
Kent Cams
APE Vernier Cam Gear with Oversize Heavy Duty Roller Cam Chain and Gears
ARP Billet Cam Chain Tensioner
Cometic Head Gasket
ARP Heavy Duty Head Studs
APE Heavy Duty Crankcase Studs
Carrillo H Beam Con Rods with ARP Heavy Duty Big End Bolts
Wossner Turbo Low Comp Pistons
APE Uprated Oil Pump Gear & Pressure Relief Valve
100thou Base Plate
Nova Heavy Duty Output Shaft
Heavy Duty Shift Shafts
Extreme Engines Modified and Undercut Gearset (Less than 7 hrs old)
Extreme Engines Modified Gear Selector Mechanism (Less than 7 hrs old)
APE One Piece Clutch Centre
APE Heavy Duty Clutch Springs
Nova Billet Clutch Slave Cylinder
TTS Dry Sump with Pace Pump in place of water pump.
Oil Cooler
Davies Craig EWP80 water Pump
Mitsubishi TD05 16G Turbo (New core less than 15 hrs old)
Custom Built Intercooler
Bored out Throttle Bodies
690cc Fuel Injectors
Turbosmart BOV
Turbosmart Fuel Pressure Regulator
MBE 9A4 Standalone ECU (Mapped by the Steve’s at Track N Road)
3 Bar Map Sensor
Innovate Wideband AFR Meter
Gizzmo Boost Controller and Boost Guage
I’ve probably missed a few things too.
I’m looking for £12,000
Call Steve on 07870904591
For some reason I'm not being allowed to use images from Photobucket, can anyone advise me how to put some pictures on please.
Here she is.
savage ! good luck with sale
  • 4 weeks later...
Anyone?
Knowing what I've spent on mine and it's not turbocharged this is a bargain,
I keep looking at this, but then I remember how much trouble I would be in with the wife. The problem is I am terrible at selling cars and she has finally put her foot down. If it's still available once I sell my existing toys I will be in touch.
  • 3 weeks later...
Car now sold, cheers gents.
Steve.
