Does anyone have an alloy diff housing for an English axle they would like to move on please?
Many thanks
Barny
Steve D had some a while ago.
I believe you are right there , would certainly be worth a shout , Steve's having a clearout quietly so would be worth a call / email / pm .
I have 2. Will call you in a bit
Cheers Dave, Julian - I'll give Steve a call tomorrow.  Already raided his collection once!
Thanks also Phil, it's an english alloy casing (live axle) that I need - if you've got one, let me know.
If anyone else happens to have one kicking about that they would like to see put to good use, please let me know!
Cheers :d
i still can't believe you sold the mighty cross flow BCF…..  I'm in mourning and having counselling  :p
You and me both! It's all gone now, even the engine mounts :down::cry:  They went to a good home though, along with the twin carbs, hi-torque starter and exhaust manifold.  They'll be showing the Nurburgring how a real mighty motor goes in a couple of weeks!!! :cool:
Gone but not forgotten :yes:
I'm sure I'll be back in something crossflow powered again one day, but for now I'm ploughing on with the awesome XE :angry:
Back on topic, it's one of these I need please:
apologies for the thread drift young Barney - may the XE and its new diff be more than mighty :-) good luck with your quest for the diff carrier
Theres a new one on ebay
Expensive though !!
Thanks Steve, yeah I've seen that one, the seller is off their rocker. Burton sell them for £390, so for eBay to be more expensive means there's a problem!
Cheapest (new) I've found is £290 + vat, which is a lot of money. Still searching so if anyone has something, please let me know.
Bump - can anyone please help me out before I have to shell out (and die a bit inside) for a new one?
Whats wrong with your current one
Or is it cast and your shedding weight ?
Yep, pure weight saving I'm afraid, there's a good 5kg difference in them. I'm aiming to only have to do this once (hah!) so hence doing it now.
5 kg of strength maybe ?
Yep that's a possibility Mike, but I think those are pretty well quashed rumours now. The current ones are made from pretty robust alloy so fingers crossed that won't be a problem.
