168bhp Silvertop + MT75 (almost drop-in package)
Due to changing to a turbo engine I have for sale my old setup -
2.0 Silvertop Zetec 1994 Zetec (pre-CAT)
Rebuilt 2,000miles ago with bags of receipts
3kg race flywheel
Brand new clutch and pressure plate
Modified Westfield release bearing
MT75 gearbox
Fuel pump
Polo Radiator
GSXR-TBs
ST170 inlet manifold and fuel rail
Piper X dome filter
Brand new alternator
Brand new starter motor
Scholar race engines modified and baffled sump
Fisher Exhaust Manifold and Exhaust Can (sub 96db)
MBE ECU and Loom (complete with wiring diagram)
Produces 168bhp/145lb ft (print out to prove)
Bits missing -
Engine mounts
Gearbox mounts
Accelerator cable
Fuel lines
Coolant lines/hard pipes
Prop
Works perfectly, goes very well - check my YouTube channel (davebgsi) for videos of it working.
Collection from Huddersfield only. I have no crane so bring a mate with you to lift it into a van/car.
£1,700 ovno. Will not split.
Hmm tempting. Need to cosinder (money aside) what else I'd need as I'd be converting to injection. As i want to add a swirlpot hopefuly jsut a high pressure pump on top of my existing set up.
If you take off what what you have already Matt , you would have loads of bits to sell to offset it anyway so wouldn't work out at a lot for you , you've got the missing bits ................. I wouldn't have thought it would be here long !
I'd you've currently got carbs then you'll have a lift pump so you just need the swirl pot and a high pressure pump.
In fact I have my old high pressure pump that I'll throw in for you.
Btt - offers?
NB. The engine was fully mapped by Noble Motorsport and idles perfectly from cold as well as being a pleasure to drive in all temperatures and speeds.
Provisionally sold.
