Here's the video of Graham's spin at Loton Park yesterday  :down:  Good to see your OK Graham that looked like it could have been a nasty one.
Ouch
Ouch
Ouch
Hope it's not too big a fix.
Ouch. Wheel on the grass the cause? Hope it's not an expensive fix.
Easy done mate, hope you and the car are both ok
Hi Folks
Car is worse off than me but hoefully not as bad as last time!
Thanks for all the support and help after the event
A very special vote of thanks to James Alexander for allowing to use his car in a dual drive so at least I could get some points on the board!
What a totally different experience in the Mighty Cross Flow
Thanks again James
G Free
  • Like 5
Thanks for posting.
Shows how a little bit of grass can bite big time.
I have spectated at Loton and seen cars go off in exactly the same spot.
I thought you took it all very well on the day and were also brave to jump into the mighty crossflow and do your timed runs.
I'm sure it won't be long before she is even better than before and lot's of help available if you need it.
David
Gluten,
My pleasure mate. Once we knew you were OK and the banter had subsided it was the only option to make something of the day for you.
Not enough people have experienced the sheer power of the 8v push rod engine - if you have a stiff neck today that will be down to the acceleration of my car.
Yours in Motorsport
James
Sorry to see this Gluty but glad you're OK, if you need any help with the rebuild give me a shout - I'm handy with a kettle!
Bad news that Graham, all happened very quickly, hope you get turned round again quickly too. :)
Glad you're not to bad graham. Hope the car is sorted soon buddy. It looked like a good roller coaster ride :/
I should think you've had enough of Loton, Graham.
I was very sorry to read of your "off" but glad you weren't hurt.
Hi Folks
Thanks for all your kind words much appreciated
Hopefully it is mostly body work but I need to get it stripped down to see it if anything else is bent
Keep you posted
Thanks again
G Free
he may need to modify the trailer too :d
I used to drive one of those ( the original bond minicar) with a soft top in 1966
