Crash test dummy Posted August 20, 2014 Posted August 20, 2014 Vauxhall 2.0 XE This engine is a saucy combination of new and used elements. It is effectively my spare hillclimb engine’s bottom end (did one short season from new) totally refreshed with a newly ported head and many other new parts added in to the mix. Should give 225bhp or more depending on induction and exhaust. Head: New and un-run Robert Cox ported and flowed head. Standard sized re-graded valves, new Piper double valve springs and new Piper steel valve retainers. New valve stem seals. QED Q450 cams with new lightweight solid lifters (not converted hydraulics) and blue Piper vernier cam pullies. Powder coated black cam cover with front lip machined off - more suited to a dry sump application but a standard type cover is available. Block: 87mm high compression Accralite forged pistons, steel H beam rods with new and un-run ARP2000 rod bolts. Bores are as good as new with honing still clearly visible - no wear at all. De-stressed block, balanced early crank with std/std journals all unmarked. Rare early billet steel timing wheel (good for high revs). New and un-run Mahle tri-metal bearings. Brand new OE quality oil pump. Water pump with cast metal impeller (i.e not the plastic version) with a nearly new pair of early type idler pullies. New cam belt. New OE gaskets all round. £1650 - no offers please..
SootySport Posted August 22, 2014 Posted August 22, 2014 Another engine for sale Steve? You trying to tempt me again? Actually mine is running great and if anyone else is thinking of buying an XE off Steve, you won't be disappointed.
Graham0127 Posted August 22, 2014 Posted August 22, 2014 Bernie....is this a hint ? Zetec went off today......should never have driven the Levante ! Are you on commission ?
Matta Posted August 22, 2014 Posted August 22, 2014 Another engine for sale Steve? You trying to tempt me again? Actually mine is running great and if anyone else is thinking of buying an XE off Steve, you won't be disappointed. Jeez it's tempting me! Will have to save my pocket money for a while yet though. Matt
pete g Posted August 22, 2014 Posted August 22, 2014 I can second that . steve knows how to build a good engine
SootySport Posted August 22, 2014 Posted August 22, 2014 Bernie....is this a hint ? Zetec went off today......should never have driven the Levante ! Are you on commission ? Not a hint for you, just stick with yer Xflow, You know it makes sense.
Crash test dummy Posted August 22, 2014 Author Posted August 22, 2014 Another engine for sale Steve? You trying to tempt me again? Actually mine is running great and if anyone else is thinking of buying an XE off Steve, you won't be disappointed. Bernie, I end up with so many good bits that it's a shame not to put them all together into a nice package for somebody to enjoy........... and I need the space 1
Burlers Posted October 3, 2014 Posted October 3, 2014 Hi, is this still for sale, a friend of mine may be interested??? PM on the wing Cheers
