MASSIVE CLEAROUT SOME PICTURES ADDED
Narrow chassis SOLD
So I have the following parts I will be offering shortly , here's a list which I will update at the weekend with photo's plus some other parts , all from my personal collection of parts
Pair of M16 Calipers , painted lovely red to make them go faster , new seals fitted never used since £30.00 plus post
Pair of M16 Calipers , dirty horrible and need a recon        £5.00 plus post
Pair of Front lower wishbones  suitable as spares for racecar maybe , they have been strengthened buy the look of them , Cortina bottom ball joint type
1 X Lower arm off Narrow car Cortina bottom ball joint type , no bushes                                              £           plus post
Steering rack well used        £25.00 plus post
Narrow windscreen frame with cracked glass ( black surround with roof fasteners )                             £10.00 plus post
Narrow Windscreen uprights freshly powdercoated black , MINT ( no not rover mirror type)                £35.00 plus post SSTC
Pair of Westfield Standard 4 point harnesses , used but clean                                                            £          plus post  SSTC
Cortina front uprights and hubs - PAIR ( steel hubs )        £100.00 plus post
Rear axle may be available ( standard diff ) once chassis has gone .
RAC Narrow Rosejointed Rollbar may be available once chassis has gone .  Lee 1st dibs Andy 2nd dibs  £175.00 plus post SSTC
Pair of New 5" black headlamps needs conversion to run car headlamp bulbs , would fit James's tractor nicey though !
        £20.00 plus post
Set of Pinto engine mounts uppers      MAY HAVE LOWERS WOULD HAVE TO CHECK                    £10.00 plus post
Wide Factory Fuel Tank   ( part number 10134 ) screw top cap , injection bowl at bottom  would suit
race car perhaps        £100.00 plus £10 post
ZK Wide tub , rear arches , scuttle , bonnet with big holes , nose cone  no front arches                      £                       SSTC
Westfield bare fabricated uprights and cycle wings (need powdercoating)come with alloy hubs
brake discs if needed       photo now at bottom of  post        £75.00 plus post
Boot rack for a Narrow , brand new cost about £100 , top quality                                                      £75.00 inc post .
Some shocks and other parts to clear , I have sold some shocks already these are what is left as noted TO CLEAR , I can't warranty these like the others I have sold .
Spax front shocks and springs off crossflow car  pair of  to clear at                                                   £20 plus post
AVO Steel bodied red rear shocks and springs off live axle car free and good condition to clear      £ plus post
AVO? Steel bodied black rear shocks and springs off live axle car to clear                                       £30 plus post
Westfield Narrow seat squabs in beige , ideally need a recover but are usable £10 plus post .
Narrow/ prelit spare wheel lower bracket with light , one number plate tab is missing                         £5 plus post
English open diff 3.89 with small flange fitted          completely knackered       FREE TO COLLECTOR
English axle complete , shoes are worn , come with 2 x new cylinders ( 1 fitted ) , drums ,open  diff unknown condition ,  handbrake cable to suit as well , collection only (GL15 Postcode area )                                                               £100.00
Windscreen wiper motor and wiper arms and bracket removed off Narrow car                                    £25.00 plus postage
forsaleclearance002_zps1d989498.jpgUppers only on engine mounts
May update with more later
all postage prices are for standard uk  adresses , will post to other postcodes but may be a touch more
Assume rollbar is narrow fitment? Need one for my wide.
Hi Julian,
May be interested in the RAC roll bar if it becomes available
Lee..
Will take narrow uprights.
Please Julian
Julian, as per lcb post, would like the rear lights and fittings off the bodywork if you wish to split them.
Chris
Sorry Chris they are going on another car I have here :(
The engine mounts, are they the type with the steel mounting bracket that the hydraulic rubber mount with fixing bolt are fitted into, a picture would be handy but if they are that type I will have them.
Cheers Mark
What colour and price are the harnesses.
Hi Julian,
I'm interested in the headlights.
Just not sure what you mean about need conversion to take car bulbs?
Also do you have a picture of them?
Would also be interested in the roll bar if it will fit a narrow SE
Black £60 plus £10 postage , in good condition , with Westfield labels on as per below link , thats less than half new price .
http://parts-shop.westfield-sportscars.co.uk/index.php?route=product/product&product_id=606&search=4611003
Yes these have a captive nut for the engine mount round rubber , and a flat steel plate to bolt to the block , will get some photo's and post up or pm you .
Yes will get a photo and post up / pm you
second dibs to you Andy
PM re the harness sent.
DJ
Cheers Derek , 2nd dibs , but look to have gone unfortunately .
I may have another set BUT won't be sorting the second batch of stuff until all this lot is gone , time to clear some room in my garage !!
Is the fuel rank injection type, if so I might have that
Yes I believe so , will post picture and westfield part number hopefully tomorrow Ian .
