Nemesis Posted July 29, 2014 Posted July 29, 2014 The trusty BBC weather site says that all should be bright dry and sunny Tuesday and Wednesday evening...... anyone fancy a gentle potter about?? Nem...... Quote
Kit Car Electronics and Essex AO Posted July 29, 2014 Posted July 29, 2014 I'm good for Weds, Nem. 7.30 meet location TBD? Quote
Nemesis Posted July 29, 2014 Author Posted July 29, 2014 How about the Black water Leisure Center? Quote
Kit Car Electronics and Essex AO Posted July 29, 2014 Posted July 29, 2014 Good for me ;-) Anyone else about? Quote
pete g Posted July 29, 2014 Posted July 29, 2014 I might be able to make it .depends what time I get back from daughters graduation in Brighton Quote
Nemesis Posted July 29, 2014 Author Posted July 29, 2014 Net access a bit troublesome..... so I'll plan for that unless I read otherwise..... if there's a majority vote for another venue/time go ahead and change it and I'll be there..... Nem................... Quote
Pistol Pete Posted July 30, 2014 Posted July 30, 2014 Will see you there Are we finishing with food? If not I'll grab a bite to eat before heading out. Quote
Kit Car Electronics and Essex AO Posted July 30, 2014 Posted July 30, 2014 Compulsory fish and chips, Pete. Ou Poisson et frites pour vous. 1 Quote
Pistol Pete Posted July 30, 2014 Posted July 30, 2014 Great run out, thanks for the sausage and chips. Bit of a close one near the end there, must sort some brighter whiter bulbs for next time. Quote
Kit Car Electronics and Essex AO Posted July 30, 2014 Posted July 30, 2014 I thought you were using candles! Think a relay upgrade is called for... Decided I now love the aeroscreen for the visibility! Cheers for coming out to play ;-) Quote
pete g Posted July 30, 2014 Posted July 30, 2014 sorry I never made it / never got home till 9pm Quote
Tim Essex Posted July 30, 2014 Posted July 30, 2014 Sorry I missed yet another run out - work work work keeps getting in the way. Sounds like you had a good time. Quote
Nemesis Posted July 31, 2014 Author Posted July 31, 2014 At last an acceptable network connection...... Pete the way you dived into that track I thought either a corner had fallen off or you'd deployed some sort of land anchor.......... then I saw the car coming the other way and figured you'd probably thought it through and decided you wanted to live...... Quote
Pistol Pete Posted August 1, 2014 Posted August 1, 2014 Yes, was a little caught out by how tight the corner was and picked up a lot of understeer. Was going to be a challenge to get around, then a set of headlight started to pop around the bend so decided best to shoot down that escape road. Not my finest bit of driving . Quote
