Front Shocks for Wide Track Suspension (Same as rear?)
Just a punt at trying to avoid £200 for a pair from Westfield.
Need 2 no. front shocks for my wide tracked SEIW to replace the leaking one's currently fitted.
Need to be tidy and working ok - hoping someone out there has upgraded when there was nothing wrong with the standard one's!!
Happy to pay, based in Worcester - open to offers.
maybe give Protech a ring and see what deal they can do
To be fair, £200 a pair is not bad
Under normal circumstances, £200 wouldn't upset me too much.  Sadly my car is currently undergoing open heart surgery for a gearbox rebuild, therefore also a clutch, front caliper refurb and a set of 4 tyres.  All in all, pretty expensive month.  Found the front shocks leaking when undergoing all the work so just adding to my expensive woes at the moment.
I have a pair of aluminium AVO front shocks, single adjustable and come with 2.25" springs.  Not sure what the spring rates are but they came off a SEiW with CAT widetrack.  I would want £100 for the pair.
I don't know if the length is the same as required by Westfield widetrack.  If you are interested then measure your existing shocks I can confirm if the same.
I had cat wide track and they use the standard short shocks not the long ones which the factory use that's why I've just changed all mine.
I will have some SPAX adjustables with springs for sale in the next month or so if that interests you?
