Wanted: crank position sensor
The crank sensor on my 2.0 XE engine has had the cable cut so short I can't use it. Now I want to fit an ECU, I need this sensor to work.
Anybody got one spare? I can even swap it for a sensor with a v. short cable if you don't want a hole left in your engine block :D
Ta
Andy.
If thats your XE engined car on your avatar :p where`s the exhaust :blush:
My exhaust is rear-exiting - unusual, I'm led to believe, but I like it. It's less noisy for the passenger, so Mrs C doesn't moan at me as much :)
If you fancy a trip to the breakers, they are the same on the 2.0 8v Cavs, Astras, Omegas etc.
Thanks for the tip, Stu - got one :D
