I think so Terry. I suspect gearbox I'm afraid mate :(
Steve D suspects the input shaft bearing but Steve E lost about 15 secs time in his 2 practices so could the failure be a tooth off the gears as he also noted that the car appeared to jump or surge for last 200m on the fast straight to the finish.
Quaife 4 speed boxes have their gear set location set by a clamped ring on the main shaft. These have a habit of slipping, and when they do, the dogs loose contact with each other and causes all sorts of problems. My box had this jhappena nd had to be completely rebuilt at almost the cost of a new one. Its now been modified with a circlip to prevent the collar slipping along the shaft again
The 5 speed boxes have a circlip as standard I belive
Sounds frustrating Terry/Steve. Sounds like the box may need to come out, which puts real pressure on for the weekend. Good luck with it!
If its the box we will not be ready for weekend so he will need a double drive if possible!
Paul Aspden is popping round to have a quick look at it and see what he thinks!
He's a man in the know. Does the engine need to come out or can you get the box out independently?
Looks like it is just the vicious new ceramic clutch acting like an on off switch so fingers crossed we are all systems go
