Terry Everall Posted May 25, 2014 Posted May 25, 2014 Got clutch relined and installed ok with new clutch fork fulcrum from SBD ( great service) but when we drove car they diff seems to be goosed so spent the afternoon taking it out!!!!!!! Will fit 3.92 diff in and cross fingers its that and not the gearbox and hope we are ready for Pembrey. Bit of a frustrating time really Quote
Scottish Bloke Posted May 25, 2014 Posted May 25, 2014 I have a lovely quaife type 9 dog box just ready to drop in there Terry! Quote
Scottish Bloke Posted May 25, 2014 Posted May 25, 2014 Just to add, good luck getting it all sorted!! Quote
Paul Aspden Posted May 25, 2014 Posted May 25, 2014 Good luck with the diff swap, should only take 40 minutes according to John Hoyle Quote
Terry Everall Posted May 26, 2014 Author Posted May 26, 2014 Took us 1.5 hrs to remove it and will probably be same to install. How the hell John does it in that time is beyond me Quote
stephenh Posted May 26, 2014 Posted May 26, 2014 I think it only took me and a mate of mine just over an hour to do mine last year, so I think you're slipping Tel! Quote
John Loudon - Sponsorship Liaison Posted May 26, 2014 Posted May 26, 2014 Terry obviously doesn't know which spanners to use of by heart and uses more bolts than is necessary. Practice makes perfect Terry Quote
Paul Morcom Posted May 26, 2014 Posted May 26, 2014 Trouble is Terry is such a tight fisted Yorkshire man so he only has one adjustable spanner to use. Quote
Terry Everall Posted May 26, 2014 Author Posted May 26, 2014 Diff changed and we still seem to have a problem When you release clutch in 1st it sounds like the back end ( diff- now changed so its not that) is going to break apart. The vibration shakes the back end until you build up to say 3000-4000rpm when it seems ok. Its a bit like axle tramp on old cars or something loose or a halfshaft but I can't see anything wrong with them. Could it just be the ceramic clutch being a bit vicious as it beds in Quote
Terry Everall Posted May 26, 2014 Author Posted May 26, 2014 They are bolt on lobro joints Steve where EXACTLY do you mean when you suggest Input shaft bearing? Do you mean the main input shaft to the gearbox from engine? Both diffs gave same problem Quote
