ITG air filter
John Loudon - Sponsorship Liaison
ITG Megaflow air filter to suit 4 cylinder in line applications
Model JC50/S125 - sausage filter (domed ends and profile) 125 mm max depth. Good for 90mm long trumpets
Used but just cleaned and re-oiled so ready for action
£50 - can deliver to a Speed Series round or £10 postage
John
jloudon-at-usa.net or 07971 576848
hi john,
I don't suppose you know if this will fit on the same backplate as the pipercross filter set up for jenvey throttle bodies.
from the pics I've seen they look very similar.
cheers
phil
Sorry but I don't know for sure but I would expect it to if the fasteners are the turn buckle type
it sounds promising but would like to check first but if it does i'll def take it.
do you ever get to the Warwickshire meet at hatton?
if not could we arrange a convenient date/time/location to meet up.
Hi, Sorry but I don't frequent the Warwickshire meet as its the opposite side of the county to me. However, if its what you want I am sure we can sort something.
PS - if I was in your position, I would make the backplate fit for the cost saving of a new filter. Should be an easy task if you can cut, file and rivet
ok, i'll contact you off line to arrange something, I work in warwick 3 days a week so can hopefully arrange to pick up sometime next week.
cheers
phil
