Detachable steering column
For sale column with detachable boss and wheel.
wheel is 280mm diameter and flat bottom.
column is 780mm long measured from end of spline  to inside of steering wheel
£40 collected or £10 posted UK
I am interested in this, but need to find out how easy it is to fit... and if it would fit on my '98 SEW? And also if the length is longer than my current column. Collection is from... ?
Second dibs please
Can be collected from AL3 or TN8 whichever easiest.
Quinten, will you be able to make your decision by Wednesday?  Just best to manage expectations for others who may be interested.
If replacing the steering column is as easy as
a) undo the bolt at the UJ
b) yank the column out at using the steering wheel
then that takes care of question 1 ;)
I need to measure my column diameter and length. It may help if you measured your column diameter? How many splines at the bottom?
Collection from AL3 would be suitable for me (I work in HP19).
In short, I will measure up and get back to you tonight. I don't want to hold your sale up unnecessary.
It came off a 2005 standard megabusa.
I will measure the spline but it won't be until Wednesday.
Regards
David
I'm going to pass on this.  Measured (as good as you can measure it whilst in place) and mine seems to be around the 80cm.  Even if that's a bit on the optimistic side, I am looking for at least 10cm extra length, which yours is not going to give me.  Thanks for giving me some time to check things!
will take if available please
Thanks for the quick clarification Quinten.
Next in line Budslater then Will
Still interested, car is at the garage getting a wheel alignment, get it back tomorrow night so will measure then. Are you ok to wait till then?
yep no probs.
I'll also confirm spline Wednesday but I think fairly standard on recent cars
sorry budslater missed your post mate :-)
The spline is 14mm diameter
Perfect, consider it sold. Can you send me your payment details please?
Yep I will send you a PM
