Megasquirt ECU and wiring loom, MS1 V3 with coil drivers. Running the latest firmware 029y4a. Comes with comms cable. Has a map for the 1.8 injection zetec on it.
£150 +P+P
Please note - as I work away from home, I won't be able to send any items out until I'm back at the end of the month - Sorry !
Hi,
Has it got The coil drivers for Ford EDIS coil packs and did you use a TPS and Trigger wheel input.
It is fitted with direct coil drivers as my setup never had an edis module. I used a TPS, but the wheel input was from the flywheel I believe. HTH.
these can be configured to run edis also via internal mods and config changes.
edis is a standalone ign module that drives the coilpack, this particular unit does it independently.
Is it something simple to convert it? It's not something I currently know anything about
its not difficult but you need to be able to fathom the requirements and make solder connections. if its not your cup of tea its more difficult.
but why change it ? this unit does not need edis, earlier units used edis as they didnt have the coil drivers built in.
i will add i have no connection to seller :t-up:
I would be running it on a duratec which currently uses edis.
I wouldn't need to use edis could run it all from megasquirt and trigger wheel
Hi
I could be interested in this.
Has it got 2 or 4 coil drivers? 2 I suspect for normal wasted spark coil.
Obviously Jacko you got in first  :t-up:  so wont step on your toes, but if you decide its not for you I will jump in.
Thanks.
Ian
Judder.
I will take it please. Will pm you
Provisionally sold to Jacko
