Is this a new feature and am I the first to use it??
Do you mean the little push button at the lower right of posts?
If so, it's been in use for a little while.
What button?
What button?
Yeah! What button?
It's a button available to the OP in the Tech Talk area that says "Mark Solved" so when a reply gives a solution that works, the problem is solved.  This post then shows up as "Best Answer" and goes green, and the thread is tagged with "Answered" in the thread list.
An example:
http://forum.wscc.co.uk/forum/index.php/topic/108080-wiring-on-the-back-of-my-ignition-switch-bl-type/
Afraid you are not the first, not that i would claim to be the first in anything, but i've used it a couple of times  :p  :d
ETA: just had a quick look book at posts; squillions of peeps have used it  :d , it is a good way of stopping a thread lingering on  :yes:
I like it.
Just wanted to be first at something  :down:  :down:  :down:
Martin you were the first to be wrong thinking you were first
Hope that helps
