Richard M Green Posted April 28, 2014 Share Posted April 28, 2014 I bought these for a project which I never got around to completing, so now they’re up for grabs. VDO part number 360-081-030-138C They're dual function: resistive sender and NC switch: The pressure sender works from 0 to 10 bar (150psi) and the (low) pressure switch opens at 1.25 ± 0.3 bar. The terminals are different sizes to avoid confusion: one is ¼” the other 3/8”. Earth connection for switch and sensor is through the body. It is an 1/8” – 27 NPT male fitting. They’re £39 each from VDO I’ve got two of them, both brand new, £20 each plus P&P, or £35 for the two including P&P. Please PM me if you're interested. Link to comment Share on other sites More sharing options...
Norman Verona Posted April 28, 2014 Share Posted April 28, 2014 Not wishing to hi-jack but I think I've got an oil pressure gauge and pipe that will end at that sender. If it helps Richard then someone can have it fo a few beers. Link to comment Share on other sites More sharing options...
Richard M Green Posted April 28, 2014 Author Share Posted April 28, 2014 Ah, I think you're referring to a (dare I say traditional?) capillary gauge Norman... unless you can push electrons down that pipe that you're kindly offering... Link to comment Share on other sites More sharing options...
Norman Verona Posted April 29, 2014 Share Posted April 29, 2014 Hang on a minute....... Yes you're right. The sender was mounted on the pedal box and a plastic pipe went from the block to there. It was over 10 years ago so may I be forgiven? Please? Pretty please, Sir. 1 Link to comment Share on other sites More sharing options...
