anyone using a koso multifunction speedo ?
I have tracked down a drawing but it's not clear what the oil light requires.
Speak to Andy at Scottish Kitcar Centre (01620 880763) - he's a KOSO supplier/fitter. Tell him Rab sent you ;-)
cheers, rang andy, he thinks it will just go to ground via oil sw as normal. :t-up:
Which one have you got?
I have the RX2n 10K and I think it's the existing feeds I use although I did replace the temp and speed sensor with the ones supplied and had the fuel gauge convertor installed.
It's a d64 I think, most is clear enough but the way the oil warning lamp was used isn't clear. It's only a warning lamp.
