Mark Williams Posted March 5, 2014 Posted March 5, 2014 7" 3.14 Sierra Diff - push-in shafts, non-LSD, as removed from donor SOLD Cheers, Mark
Truly Skint Posted March 11, 2014 Posted March 11, 2014 Hi Mark, out of interest what have you fitted in place of this. I have one with push in shafts and have struggled to find a LSD with push on's at a reasonable price. We did find one with lobo's but was unable to swop the bits over to make it work. Any suggestions would be great Cheers Mike
Mark Williams Posted March 12, 2014 Author Posted March 12, 2014 Hi Mike, I'm can't be much help I'm afraid - I'm currently using a 7.5" lobro diff and bought the 3.14 7" for the crown wheel and pinion, but have since decided against moving down to a 7" unit. I think the only options you have for fitting an LSD and retaining the push-in shafts are the Quaife ATB or Titan plate units (as used by Caterham) and, although they aren't cheap, they should be a straight swap internally. Changing to lobros would give you more options, but you'll then need to swap your driveshafts (and possibly more) unless you look into modifying them by replacing the inboard tripod joint for a lobro as BEN99W demonstrated here, and that might not work out to be any cheaper. Cheers, Mark Also my 7" 3.14 is now sold
Truly Skint Posted March 13, 2014 Posted March 13, 2014 Congrats in the sale. Thanks for your feedback Cheers Mike
