O/T Key caution / Theft
John Williams (Panda) - Joint Manchester AO
Just had car broken into on the previous night.....
no damage to windows/locks etc... so been very confused how they got in, coppers said I must have left the car open...  Not convinced on that, also the car locks itself when unattented so likely hood of unlocked is pretty small
Anyway after a bit of thinking we have a way that it probably happened.
We leave all the keys in a key safe apart from the one at night to lock/unlock the front door (in case of emergency) which has a car key on, that night it was my golf.
so we are thinking that they went in through the letterbox with something and pressed the open button on the key fob, because I still had both keys.
volia now minus one laptop and bag and not insured as it was unattended
not a happy panda
Mates just had his focus done the same way
Lost i pad and sat nav
Scumbags use scanners
Wait nearby and wait for you to operate the remote
The scanner will read the frequency and duplicate it later when the cars unattended
Lots of execs going in multistorys in london at one time , the big posh ones now have plate rec so you cant use any ticket to get out
They will always find a way - eventually
I have a rake pick that will open most VW in about 5 seconds and I can normally pick a ford tibbe lock in about 20 seconds
But the alarm sounds when the doors opened
So from what you've said no alarm requires the remote to be operated to open the car without the alarm
Scanners can be bought from China for about £250 last time I looked, but without the original signal frequency it won't work
Even with a scanner you don't override the Immobilizer chip in the key so it still won't start to drive it away
As you say keep your keys out of sight and reach
A rather up-market clothes shop was losing stock and the owners were baffled: the nature of the shop meant shoplifting was unlikely and the premises were alarmed at night.  Nevertheless, items were disappearing and the realisation dawned slowly dawned that it was happening between the hours of closing and opening.
It turned out that a local scrote was going out at night with a long fishing rod, but it wasn’t fish he was after: the rod with a hook on the end would be inserted through the front door letter-box and then the ‘catch’ would be slowly pulled back...
Take care!
R
Don't have the issue thanks to the small white furry chap in my avatar, the late Barkley.  His favourite daily fun was to see the postman coming up the street and wait under the letter flap in the hall, quiet as a mouse, and then snatch the post out of his hand as it came through the flap and rip every envelope and flyer to shreds.
Needless to say, it was eventually blocked off and a post box attached outside.
Also keep all my car keys in the bedroom with me, along with a cricket bat, with ball and pads as well so no one can accuse me of pro-actively looking to cause GBH.
I friend who lived in a nice area had a mgf a few days after they came out
Scrotes took his bay window out the lounge,in the hall,nicked the keys and his leather jackets and off they went
They slept above and didnt hear a thing
Only noticed when they walked in the lounge and it was cold
Car was 1/4 mile away with the front end stuffed
The AA opened my focus in about 30seconds (not saying how here) , but an old inflatable lumber support helps - its dead easy to get in and not leave a mark.. If its dead locked apparently then pressing the start button unlocks a lot of cars..
lot easier than playing with letter boxes....
( I got locked out by throwing my coat, with keys in it ,onto the back seat. When I then shut the rear door the whole car locked, but in this case not dead locked  - AA man sez lots of cars do it on odd occasions)
