solid zetec cam followers
Hi.I need four solid cam followers so I can do a dry run on a new cam set up.The cams I have are Newman phase 3 for hydraulic followers. You don't get full lift with hydraulic cam followers until the engine is running. Until the oil preassure has filled them with oil they are short on the full lift. This is so I can see if there is valve to piston contact. I have new followers before any bright spark tells me you should fit new with new cams.it is only for a dry check. My engine is a 1800 Silvertop but don't think makes much difference as long as their solid type. please email me. I will pay the going rate plus postage. Thanks Gray. subsy1@Gmail.com mobile 07775810114
Bump.Anybody PLEASE!
Have you made a call to a local engine recon outfit
Be surprised if they didnt have a zetec head sitting around - even a scrap one
Thanks blue ass worth a try
