LIGHTWEIGHT BATTERY AND ALTERNATOR
Robust?  I’ve no idea what you mean.
In that, if he is re-listing the part a lot, making hard to keep track of the current listing number, his seller id will probably not change, and hence remains a stable way of finding the seller and hence items. Links as below.
http://www.ebay.co.uk/usr/powervamp-racing - Battery Supplier
http://www.ebay.co.uk/usr/carl-foggaty - Alternator Seller
Daniel
  • 2 weeks later...
Just doing a mock fit of the alternator to my silvertop zetec, it seems the original tension bar won't line up with the bolt hole on the alternator
Any suggestions?
I drilled the 8mm thread out
Got some 8mm threaded bar bent 90 degree at the end to pass through
The bar then heads toward the rocker cover,secured by a bracket bolted to the head lifting eye bolt hole
With the pulley off the zetec alternator a 900mm 4 ribbed belt fitted perfectly
http://s1102.photobucket.com/user/19sac65/media/Mobile%20Uploads/image-1.jpg.html?sort=3&o=1
Right that's great thanks fellas I'll see what I can do using the pics posted
If you want to go the turn buckle approach, McGill Motorsport is an excellent source for the right and left hand threaded rose joints, along with the right hand/left hand threaded bit in the middle. Good prices too.
Here you go, turnbuckle links, clicky
If you want a more budget version of the rose jointed turnbuckle, try a chandler/boat yard, they usually have turnbuckles available for tensioning lines on boats.
  • 1 month later...
A question for the guys running the small alternator
last night I finally set about swapping over the pulley wheels and when I came to fit the original pulley to the denso alternator the shaft is about 2mm thinner than the hole of the pulley, did any of you have this issue?
Yes,i did post it somewhere
A denso is 14mm shaft - standard ones are 17mm
You can make a little shim to hold it true
I filed down a steel dowel and cut a slot in it so it opened up to slide on the shaft
I was going to use a 15mm copper olive but couldnt find one
Once its central the nut will hold it secure
