AeroDynamix Boxing Day
Steve_Farrimond
Just though I'd share what I've been up to today. AeroDynamix diffuser.
e08313f15bbd52b46bbfcacaf9f97921_zps8730
579c62b95722823bf457292153fda4ed_zps8c01
85294df509c5991142adafd07dc76da2_zps9526
c02317f9cccf72e57b41d40447d471b4_zps1321
eda7c095a2d704c411cbfbb9ecd82202_zps857a
0c5504adf552d4886eaa2e794dcd771d_zps5025
Link to comment
Neat. Will have to have a shufty next time we catch up and you've got it...
Link to comment
Ramps
http://www.cjautos.eu/product_p/cr01.htm
They're really good, unless you need to take a wheel off
Diffuser
At the end closest the front, you attach a small u shaped aluminium beam. This acts as a hook to hold the front end of the diffuser.
At the back you utilise the brackets for the spare wheel carrier. You then fit an old school bonnet catch. One either side.
Then still and fit the bonnet catch to the diffuser.
Once fitted its a 10 second job to remove the whole diffuser.
Link to comment
I found a diffuser made a huge difference to stability at speed and stopped my front end getting really light above a certain speed.
I had a thead on making and fitting one. I drilled into chassis with 6mm holes, used a tap to make threads then just used silicone on top of holes in diffuser (to stop water and rattles) then put a bolt/washer in. However I now have the old school bonnet pins instead, to allow easy access to check fuel lines and diff.
I notice that you have no strakes on your diffuser, during my research it commented on their effectiveness in several sources. I fitted 6 strakes (including 2 outer edge fins).
I do like the looks of the Aerodynamix diffuser and after deciding Ali would be better than GRP, I have now realised that it wouldn't make too much difference either way.
Little shot of mine.
91878C5C-6D41-431F-A40E-1A4CFA71B7A2-323
Just to show. Would be great to switch and swap to see difference between two. I doubt very much there would be any noticeable difference at all though.
Link to comment
Excellent Steve , always nice to see parts fitted . Nice looking car by the way ;)
There are some photo's on the website of the underside fittings on the website as per the link as per Steve's description :
http://www.aerodynamix.co.uk/rear-diffuser.html
Excellent to use the ramps whilst fitting so the suspension is not in droop ;)
Edited to add strakes are on the to do list but it's a pretty long list at the moment :(
Link to comment
Ouch those ramps are nice, but also carry a nice price tag!
Link to comment
Those ramps are a great, must get some.
like diffuser idea, will it make me go faster? or is just a styling feature?
Link to comment
The manual versions of these style ramp have a bit of a reputation for being a pig to put up and take down.
Link to comment
thanks for the comments on the car.
I would like the Strakes, but i'm sure the whole thing looks a lot better, than performs.
Ceriloi - I think this will just be in your head surely? I don't believe the car will handle any better with this attached.
the ramps are great and available to lend if your local. personaly I wouldn't get another set, there great for the above task and servicing. everything else requires wheels off and therefore renders the ramps useless.
it takes about 30 secs to pump the ramps up. i really wouldn't want to use a ratchet.
Link to comment
Steve - these will be ideal when you help me with my diffuser, and bushes, and bearings, and steering mounts, and .... :-)
Link to comment
