JOCKER Posted December 18, 2013 Posted December 18, 2013 I need to replace my steering racks mounts as they are quite corroded due to a leaky coolant pipe. Will these fit the bill? http://www.rallydesign.co.uk/product_info.php?cPath=900_1670&products_id=7335 Cheers Jocker Quote
Mark (smokey mow) Posted December 18, 2013 Posted December 18, 2013 They should work fine and look very similar to mine Quote
simon besant Posted December 19, 2013 Posted December 19, 2013 I got so I bought some of these they are fine but had to dress some material off to get them to fit over the rack Quote
Dave Eastwood (Gadgetman) Posted December 19, 2013 Posted December 19, 2013 They look very similar to my Cat Motorsport clamps. They were a tight fit too. Don't remember having to remove any material, but it was a close thing! Quote
Mark (smokey mow) Posted December 19, 2013 Posted December 19, 2013 I seem to recall mine were from Burton although .i suspect they're all basically the same. I did have to increade the radii of of the corner slightly as when it clamped down the corners would bind before they were seated correctly. Quote
JOCKER Posted December 19, 2013 Author Posted December 19, 2013 Cheers gents - any alternatives as these are double the price at Westfield Quote
stephenh Posted December 19, 2013 Posted December 19, 2013 They look like the Westfield optional competition mounting brackets. Quote
Dave Eastwood (Gadgetman) Posted December 19, 2013 Posted December 19, 2013 That's because most of RD's stuff is cheaply sourced in China! (That's not to say it isn't any good, but the quality can be variable. I've had decent stuff from them, and I've had stuff I was so disgusted with I refused to fit to the car - the wide track) Quote
bigals Posted December 19, 2013 Posted December 19, 2013 A bit more money but over on the bay http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=271327175767 Look to be milled not cast, 1 Quote
Mark (smokey mow) Posted December 19, 2013 Posted December 19, 2013 Cheers gents - any alternatives as these are double the price at Westfieldnote that the Rally Designs price is excluding VAT whereas the Wesitfield Price is including VAT Quote
JOCKER Posted January 3, 2014 Author Posted January 3, 2014 Thanks for the link bigals - ordered these the other day and they turned up this morning. Far cheaper than the Westfield versions. Cheers Quote
