davidgh Posted December 7, 2013 Share Posted December 7, 2013 1990 SEi (narrow independent) BRG rolling chassis. Q registered. Two owners from new -- both current club members. What's not there: -- engine (and ancillaries, plumbing, exhaust), -- gearbox, -- prop-shaft, -- battery, -- oil pressure and coolant temperature gauges. What is there: Hard and soft springs (400/200 and 250/150) Avo shocks 4.4 LSD Westfield alloy front hubs and 4-pot brakes Polo radiator 9 litre fuel tank, plumbed via a separate 1 litre swirl pot to high pressure pump Return fuel circuit to swirl pot Front and rear ARBs Full cage (Plays-Kool) Quick rack Aerodynamix aero-screen Lightweight bonnet Bolt in extra chassis and diff-carrier stiffening RaceLidz FIA driver's four point harness (2017) V5c (registered as a Westfield) MOT certificate valid until 04.04.2014 This car has been used for sprinting, hence the specification -- don't worry though, the chassis is straight. In fact it's a pretty well set up chassis (thanks due in large part to Gary Smith). Running a 1600cc VX engine, and piloted by an OAP, it has managed some quite respectable results in the Speed Series, and has not been beaten in class at Borough 19, TWMC and RMC sprints in the last three years. It could also be returned to road spec. In addition to the above, it comes with a full factory screen, with wiper and washer systems, and side-screens, a normal cruising fuel tank (not compatible with the diff-carrier bracing), a shell driver's seat, and a boot box (which would need to be cut for the cage). For the road, though, a good tidy up would be called for The car is for sale with 14x6" Minator wheels fitted with 185/60 Avon CR28 rubber (with lots of tread). You would need to collect (trailer, of course) from Suffolk. Asking £4200. [/url] Link to comment Share on other sites More sharing options...
alexander72 Posted December 8, 2013 Share Posted December 8, 2013 PM sent Link to comment Share on other sites More sharing options...
davidgh Posted December 19, 2013 Author Share Posted December 19, 2013 Bimp! Somebody must want to build their own car without the hassle of IVA! PH after Crimble. Link to comment Share on other sites More sharing options...
davidgh Posted February 1, 2014 Author Share Posted February 1, 2014 Deposit received with thanks. Link to comment Share on other sites More sharing options...
alexander72 Posted February 1, 2014 Share Posted February 1, 2014 Great News David Link to comment Share on other sites More sharing options...
davidgh Posted March 28, 2014 Author Share Posted March 28, 2014 SOLD -- and emigrated to Scotland! Link to comment Share on other sites More sharing options...
