can you guess what its going to be?
Phil, what exactly does that bit of kit do ? forgive my ingnorance.
Its a cam sensor to tell the ecu which cycle cyl 1 is on. This is needed as I run fully sequential injection and ignition. (1 injection and spark per cycle) most do away with this and run semi sequential or batch firing ( 2 injections if half the required fuel and 2 sparks (wasted spark) per cycle). Semi is perfectly fine but gives u less resolution to adjust the fuel. As I have chuffin massive injectors and because I like to be different I went fully sequential.
Tell you what Phil, it'd make a snazzy coin holder if it doesn't work!
Soz, couldn't resist.
will make you one if u like though its a bit over engineered
Sounds good, think how many mint imperials it'd hold?
You could make a fortune manufacturing these, a cup holder for really small cups.
espresso on the move. like it  :yes:
Should I have one of these on my cross flow?
It sounds good so I think I need one mate.
yes!!!!
For holding coffee or mints  :p  :p
I'm going to make one tomorrow in my wood lathe - can't be that hard :-)
Or a vodka jelly shot mould  :p
slight design change it now looks like this
Bush remover?
Sounds painful?
