can you guess what its going to be?
Filfan developments have been busy tonight and nearly finished my latest project.
Can you guess what its going to be? it has 1 machining  operation left to do tomorrow which will be done on the mill. its not a coin holder the 50p is for scale.
Oil filer cap magnet........ ???
nope though thats a good idea :p
Bush remover?
Cup holder
Don't know, but looks remarkably similar to the drift I made for fitting XE cam seals!
(Though as that didn't need milling, i guess it's just a coincidence).
Nope it will be a permanent part of the engine
Nut catcher :d
Cam mounted trigger wheel.
bingo
The prize is a very lucky M8 nut. Or unlucky depending on how you look at it
It was the fact it reminded me of the seal driver for the other end so much, only put two and two together when I reread the bit about milling it.
Nice work. What are you using at the moment, or are you still batch fire?
No am using the hall sensor in the dizzy but the cams in the new head dont have the extended exhaust shaft. The trigger wheel will replace the big washer that holds the pulley on. All the testing will be done on the engine before swapping heads so I know it works
Ah, I'd forgotten you'd still got the dizzy assembly in place.
Always good to see someone trying something different on the XE.  :yes:
had a spare hour today so got the thing finished
rather than a tooth i opted for the cut out as this is what is in the dizzy
will get the nose off the car later and look at making the bracket to fit the sensor
