dombanks Posted November 22, 2013 Posted November 22, 2013 is it worth getting a cable plug in dremel over the battery versions? i have no idea about these and need one for doing some trimming to stuff in the lab http://uk.farnell.com/dremel/3000jb/rotary-tool-240v-15-acc-uk-plug/dp/2213597 http://uk.farnell.com/dremel/7700/multitool-7-2v-ni-cad-cordless/dp/1869037 http://uk.farnell.com/dremel/8100-1-15/multitool-7-2v-li-ion-cordless/dp/2314516 http://uk.farnell.com/dremel/8200-1-35/multitool-10-8v-li-c-less-35accs/dp/1869033 Quote
FILFAN Posted November 22, 2013 Posted November 22, 2013 I got the battery one and a 240v. I prefer to use the battery one though it's better than wires everywhere Quote
SootySport Posted November 22, 2013 Posted November 22, 2013 Battery one is good for no wire to worry about but rechargeable batteries do run out of puff and loose charge easily over a period of time. Mains tools always produce power infinitely. If you are an occasional user the battery one is the one to go for. Quote
pistonbroke Posted November 22, 2013 Posted November 22, 2013 I got the black and decker one , half the price twice as good Quote
Mark (smokey mow) Posted November 22, 2013 Posted November 22, 2013 I've owned both the wired and battery versions. I started out with the one in your first link, but when I burnt out the motor i replaced it with the one in your second link. In hindsight I wish I'd saved the money and gone for another wired one. There's not many occasions when I use the dremel away from the workbench area so having a battery isn't such a benifit I was expecting it to be, more often than not I don't use it for a couple of months and when I do, the battery is normally flat and needs a recharge first The body length of the battery version is also longer than the mains wired so it's harder to get it into those tight to reach places on a Westfield. Quote
pickmaster Andy Lowe Posted November 22, 2013 Posted November 22, 2013 I've had the second one down for about 3 years I get a good hour out of the battery still Working on site locksmithing it's perfect Great little tool For small work in the garage on the Westfield I like air powered tools, better power and smaller Quote
User0083 Posted November 22, 2013 Posted November 22, 2013 I've had both and cheaper versions. Li-Ion is the best and Dremel. Had a cheap battery version, lasted about a year, got a cabled one... Just didn't seem any good. Do got a battery version, Dremel, and works really well, had it a few years now. Obtained a cabled one, boot of a car a brought, was great, just cable got in the way. So lent it out and it never came back! Quote
Northwarks Posted November 22, 2013 Posted November 22, 2013 Dremel cordless here - had cheap 'copies' before and they just don't last. Quote
Rich8977 Posted November 22, 2013 Posted November 22, 2013 Dom I got one from machine mart, not had any problems with it, cost about £40 Rich Quote
dombanks Posted November 22, 2013 Author Posted November 22, 2013 I need one for the lab so work is buying, I'm limited on the places I can buy, god bless the inefficency of institutional procurement, so one call is the easiest and Dremels are the only few options Quote
Wile E. Coyote Posted November 23, 2013 Posted November 23, 2013 Whichever you go for, take care with it. They're easy to get complacent with, and temptation to get closer to the working end than you would with a bigger angle grinder etc, but if a disc goes there's potential for some nasty injuries. Quote
User0083 Posted November 24, 2013 Posted November 24, 2013 Whichever you go for, take care with it. They're easy to get complacent with, and temptation to get closer to the working end than you would with a bigger angle grinder etc, but if a disc goes there's potential for some nasty injuries. Second this! I always have safety specs on. I've had cutting discs explode and hit the slsaftey specs... Quote
