fil46 Posted September 11, 2013 Posted September 11, 2013 First time out for me at cadwell park and loved it , quaified 1.37 got a 1.34 race 1 and got right on it in race 2 with a 1.31.048 vid from race one it gets good after the safety car Quote
Speed Freak Posted September 11, 2013 Posted September 11, 2013 at 17m10 I think I would have pood in my pants-pushed into the grass at well over 100mph...- and then at 18m42 the same guys cycle wing decides to depart flying past you! you and the other car (caterham I believe) were very similarly matched- seemed like he had a quicker up and go from lower speeds, but you had the advantage at high speeds- the yellow car is a beast down the straights-what sort of power is he pushing out? 600+? Quote
Andrew Posted September 11, 2013 Posted September 11, 2013 The other seven is a live axled Westfield.. There's nowt between them for straightline speed is there. Bet Garry in the other Westy wasn't too chuffed with the safety car. Good stuff Phil. There's a vid from the Simon Allaway Esprit up too.. it's a bit of a monster.. Quote
Speed Freak Posted September 11, 2013 Posted September 11, 2013 what engine setups are the westfields running? High end duratecs? I know everything looks different on a video, but they looked extremely rapid. Quote
Andrew Posted September 11, 2013 Posted September 11, 2013 what engine setups are the westfields running? High end duratecs? I know everything looks different on a video, but they looked extremely rapid. I'm sure Phil will confirm, but as far as I know, neither are Duratecs. Phil's is a Vauxhall (260bhp Phil?), and Garry's white car is a very high spec Zetec. Quote
fil46 Posted September 11, 2013 Author Posted September 11, 2013 My car is vauxhall powered steel bottom end big valve head, 2 litre with 275bhp 200lbs torque, and independent rear axil. Garrys car is a 2.3 zetec with about the same power and a live back axil. top speed was 132.8mph down the back straight. Quote
Speed Freak Posted September 11, 2013 Posted September 11, 2013 well I didn't do very well did I! First thinking it was a caterham in front, then thinking duratec power- You hear all the time of big numbers from c20xe's and duratecs, but those hp numbers from zetecs are huge! Those cars were rapid. Quote
Cam Posted September 11, 2013 Posted September 11, 2013 Hey Phil....... good to see you on the boardroom Looking forward to watching you all again at Oulton, Looking forward even more to be back out next year mixing it up with you all. See Ya Cam Quote
