Pantherman Posted August 24, 2013 Posted August 24, 2013 Thinking of getting a cold smoker , just wondered if anybody on here cold smoked. If you do what type of smoker do you use / recommend. Quote
nearly done Posted August 24, 2013 Posted August 24, 2013 You could try www.sausagemaking.org. I make my own sausage and use this firm for casings, flavourings and so on. They do a range of smokers and associated bits and bobs and provide a first rate service. Often thought of making my own smoker using all the bits of chimney flue and old fire boxes I have laying around. My Italian mate does his own sausage and hangs them above his wood burner to slowly air dry- very nice indeed. Quote
alexander72 Posted August 25, 2013 Posted August 25, 2013 I have done it in the past in an old oil drum with oak chips soaked in whiskey for a month then dried. not bad results on roadkill muntjac rear leg.... Quote
Delboy Posted August 25, 2013 Posted August 25, 2013 Bradley Smoker is a great price for a keen amateur! Quote
Paul Morcom Posted August 26, 2013 Posted August 26, 2013 I use a Bradley Smoker - it is good for home smoking but..... Costly to run and you have no choice in where to go for the brickets Cold smoking is too hot - must increase the distance from the smoke unit to the chamber - Bradley do a kit, this did reduce the temperature but still not enough so a diy extension was made. Now cold smokes fine. Smoke everything from cheese, fish, venison, chicken, partridge, pheasant, duck. I hot smoke more often than cold smoke - mainly because I have a plentiful supply of venison and game. The Bradley is good in so far as once started you don't need to worry about it. For hot smoking I do not rely on the temperature gauge and time - I always go by internal meat temperature with a meat thermometer. I have used a couple old metal dustbins, a length of pipe - worked well and was cheap to run but took a lot of effort to keep the fire in and to burn enough to provide smoke with correct heat. Quote
Si Richards Posted August 26, 2013 Posted August 26, 2013 I have one of these: http://www.forfoodsmokers.co.uk/acatalog/Portable_Electric_Smoker.html It's great for hot smoking as it comes but I too wanted to do some cold smoking so I went down to screwfix and bought a length of cooker extractor fan piping, I then fitted one end of the pipe to a metal legged box which I made, this then simply sits on top of the smoker, the other end of the pipe goes into an old cupboard which I fitted some BBQ style grills in for shelves and voila you have a rather cheap but very effective cold smoker. I originally planned to add a bathroom extractor fan in the middle of the pipe to suck the smoke through but it really doesn't need it. I smoke everything in it from meat and cheese to bread!!!! Quote
