thanks to crash for helping me rebuild my engine after its failure at mira.
been a real b******d today but we finally managed to rebuild it,, [don't ask]
engine back in car and hopefully finish of tomorrow and give it a test run in the next day or so weather dependant
thanks again steve   a true friend :t-up:  :t-up:  :t-up:
What was the diagnosis Pete
Glad you heave it fixed
still don't know what causing it but number 3 mains oil starvation i think this is what happened last year. but I carried on and destroyed the conrod.
caught this in time crank polished up ok, no other signs of damage all other bearing are mint.  did find rear bearing had less clearance this time,[ with new bearing] and spent most the day trying to sort that problem out. must of had the crank in and out about 40 times. :down:
almost gave up.
how did everyone get on today and yesterday
Mira was over by about 1445hrs
Kev Jones walloped the cones and took off rear wing and silencer
Steve hit tyres just before finish and bent wishbone, damaged cycle wing and rear wing. Thanks to Keith Adams and Barry we gor spare part and fixed for Sunday
Barry got 102, I was fastest Westfield but did not beat target
Hethel
From memory Gary was fastest Westfield and 2nd O/A
Barry got 102 I think, I beat target and was 4th fastest O/A, John beat target .... great circuit but takes some learning
They may be changing layout for next year so we may not have target times!
How's it running Pete? I emailed you the question but you didn't respond so I didn't dare to ask again.
engine seems fine .using other pump and thicker oil. pressure much better  .more stable 2.5 bar at idle hot and 5 bar reving.
never got your mail.
car in trailer ready for battle Saturday at curborough.
That Helix does seem to give a good pressure. Just keep the revs below 10,000 this time and you'll be fine. Good luck.
......... Just keep the revs below 10,000 this time and you'll be fine. Good luck.
Yeah like that's gonna happen, I don't think his dash reads anything below 8,500 :d :D
Tiggs
just back and car survived ok and knocked over 2seconds of my best time :t-up:
Well done Pete
What time was that?
curby double lapper
And the time????
good time Pete - was this a speed series event mate?
no but will be in 2 weeks time.
