I would say vibration hence why I asked the difference in your setup to others. Solid mounting seems extreem to me
Been on my car since 2011 think its been driven hard enough to prove they don't give issues!
Can't say I've noticed any excessive harshness either
You insensitive beast
:) will look at it later on today.
by doing this though do I need to do anything else to the chassis or similar to add extra strength/bracing?
Apparently not :oops:
chassis will be fine
Hi Rob,
I had some Vibra-Technics engine mounts maded for my car; they are a slight compromise between solid and rubber mounts. I can't remember the name of the guy that made them but they were specially developed for a Westfield.  They were made to my specification (height) and work very well - they don't eliminate all the engine movement, but most of it, and also reduce the engine vibration through to chassis.
I was recommended that if I went for solid/stiffer engine mounts then the gearbox mount also need to be uprated.  In my case I already had a VW Polo engine mount on my Elite Gearbox and in discussion with the guy from Vibra-Technics he confirmed that the VW Polo mount was already heavy duty/stiff for a gearbox mount and so would be compatible with the new Vidra-Technics engine mounts.
My solid mounted duratec used normal gearbox mounts with no real problems
My engine and gearbox are both  bolted up solid -no rubber-no movement
How are your fillings, Stu   :d    or    :laugh:
PMSL :laugh: :laugh: :laugh: :laugh: :laugh:
thanks guys sorted.
Some Photos from the day, plus im just uploading my video at the moment (give it week and ill add it to this :laugh: )
Nice lines Tom
