SEI Breaking for bits...most parts available
Car is a 1997 sei wide and has had a left front impact.
It is slowly coming to bits, so if you want anything other than interior, rear suspension and silencer let me know I may have it off already.
At the moment I have upper and lower front wide track, CAT motorsport wishbones (One side only) £40
AVO shock & Spring to suit. £20
Full tonneau cover for high back seats with RAC bar. Slight tear about 30mm long behind rear bulkhead which would easily repair. £40
Spare wheel cover in black vinyl £5
RAC roll bar with detachable rear stays. Powder coated in black, includes rose joints and sleeves £60
Aero fuel filler cap, complete none locking, 2" funnel and all bolts £40
Other parts available soon including C20XE vauxhall engine, complete with carbs,dizzy, coil,shallow SBD sump, alternator, inlet manifold, throttle linkage, starter motor, flywheel and RWD clutch, all water pipes and RH engine mounting.
Also type 9 5 speed gearbox with or without vauxhall bellhousing, remote extension, gearstick.
Full set of instruments and senders (Black on white background)
Fuel tank
Call to discuss prices on items not listed as they are not all off the car yet.
Tel Paul
07973 504785
Pm'd
I'll take the roll bar please
Pm'd
PM sent
Hi i am after the bell housing if you.would split from gearbox. and what price you looking for engine thanks darren
Ah so you ended up with it and outbid me :)
Is the tank a standard one, or small competition one? If the latter, can you pm me details, ie size, dimensions and confirmation of what metal it is made from? Oh, and price!
pm sent
Hi paul
 i'll take the cat wishbones provided they are the later type, will drop you a pm in a moment
Barry
Paul yhpm
Hi Paul,
Is the  filler cap still up for sale? If so I'll take it.
DerekJ
Hi Paul would you happen to have a speedo sensor up for grabs? If so could you please let me know what type and how much you would like for it.
Thanks, Sean.
PM you about the Tonneau.
What exhaust is fitted to it and how much ,please .
Wee Dov
